There is now a weight cushion available for lighter pilots to use in the Astir. It sits under the pilot and is restrained by loops around the straps.
There is also a new, separate energy-absorbing cushion which can be used on its own or on top of the weight cushion. This too is retained by loops that fit around the straps.
Up to 6 weights can be fitted in the cushion. Each weight is about 2.5 kg (5.5) lb, but check the total weight on the scales to make sure. Ideally, weigh yourself together with the weight cushion and parachute to avoid errors. If you are a lightweight pilot new to the Astir, ask an instructor how much extra weight to carry - it is better to be a bit heavier than the placarded minimum weight.
ALL PILOTS: Check whether the weight cushion has been left in the glider as part of the 'ballast' check. Otherwise you might be flying overweight!
Please treat these new cushions with care. If you don't need them yourself, remember someone else may be relying on them. Place them carefully in the bus, maybe on a seat. They won't last long if thrown on the floor or into the weight box.
Thanks,
Barry
Astir weight cushion and energy-absorbing cushion
